Speaker connection
682 Views 2 Replies 2 Participants Last post by  tristan2
I have a Yamaha RX-V1800 receiver. On the zone 3 connection I'm having trouble keeping the speaker wire connectied.
I'm don't know what the connection type is called. It consists of a small hole through which the wire is inserted and then there is a clip that is rotated 90 degrees that supposedly secures the wire.
Can someone tell me what this type of connection is called? Also, is there a plug that I can use (like a banana plug) to make the connection more secure?
1 - 3 of 3 Posts
the spring clamp wire connector is a throw-back to the early 1970's. Why manufacturers continue to use it to save a dollar or two on an a/v receiver....I will never know.
The type of wire termination often used with them is called a "pin connector"
or
depending on whether you want a screw down crimp of the wire or a compression fitting as the barrel is screwed to the pin.
you may need to use shrink tubing or electrical tape to cover the exposed metal of the connector body if your spring clamp connectors are close together. The exposed metal is "hot" and if the + and - touch each other, it's the same as shorting out the wiring.
See less See more
Thanks! That's exactly what I needed.
or
1 - 3 of 3 Posts
