1 - 4 of 4 Posts
· Registered
I am planning on upgrading my 1990's sony GA7ES receiver to a pioneer 1120 in the near future. My speakers are old Celestion SL6si's with a small (mismatched) celestion center, and a polk sub.
Having read about the importance of having a matching center speaker in a HT system, I'm not sure which way to go here. Am I better off to ditch the old SL6's and get new fronts with matching center? or should I just look to upgrade the center speaker with something more appropriate? The problem is I don't know where to find a center channel speaker that would come close to matching the sl6's.
· Registered
If you like the Celestion sound - then go to www.ac4l.com and look
at the Celestion speakers. Voiced matched fronts and center, is the
best way to go. Do you have a budget in mind?
· Registered
Discussion Starter · #3 ·
I like the celestions but I'd probably be satisfied with any decent quality speaker. I'm not super picky. I was only trying to keep them if possible due to the cost savings.
My budget isn't restricted, but I'd like to keep it under 2k as I probably wouldn't appreciate anything beyond that price point. My primary use is going to be for HT.
· Registered
Start with a receiver and since you are not real picky - Go over to
www.htd.com and look at their speakers. They are budget friendly
and sound good for the price.
Onecall.com has the Boston VR series speakers for a good price.
www.onecall.com
Vann's has the Energy RC series and Mirage speakers.
www.vanns.com
1 - 4 of 4 Posts
