1 - 1 of 1 Posts
I have a Yamaha V659 receiver and I don't know how to use the Avia test tones instead of the 659's test tones in "Speaker Level" under Manual set-up. All the other receivers that I have allow you to use the Avia's test tones to set your reference levels. When I use the Avia's test tones when in the 659's speaker level setup, the set-up screen will go out on the monitor I'm using, and I then cannot use the bar meter to set the Avia's reference tones. I suppose what I am asking is how to turn off the receivers's test tones and still use Avia? What I have done is to use the Avia's test tones on each individual speaker of the Yahama to set the reference level. Don't know if this is correct. Could someone tell me if you can turn off the receiver's test tones for the Speaker Level Set-up? Thanks
1 - 1 of 1 Posts
