Status
Not open for further replies.
1 - 1 of 1 Posts
Hi,
I just purchased the 5 piece polk rm6700 set of satellites and the sony da1000es receiver (for the bedroom)... the issue is this; there is a slight static/snow sound coming from the speakers (very noticable when the source program is muted and the volume on the receiver is turned up a little) - what would be causing this? is it normal? is it more than likely the speakers, or the receiver?
it does this on every component... whether its the dvd player (opitcal out) or the cable box (composite out).
thanks for any help!
~whiskaz
1 - 1 of 1 Posts
Status
