Originally Posted by niegowsj /forum/post/12983800
I will definitely look into moving the furniture around and reorganizing the room. I am for sure going to wall mount the rears so that it looks cleaner. The room is above the garage so I am going to have an electrician help with wiring the rears through the garage. I just have to figure out where to put them since I get one shot. Thanks a lot.
Electricians are super expensive, they make contractors & the like look cheap!
Unless it's a friend & it's cheap, you might consider doing some or most of the work yourself, especially if you don't mind getting your hands dirty.
Start here:
http://www.techtoolsupply.com/index....ROD&ProdID=649
That's a site selling "Labor Saving Devices" products.
But.. They have some way cool instructional videos on their site that you can watch for free.
Each tool you click on has videos accompanying it, well most do. Click around & see.
Then you can also do some Googling for wire fishing techniques & tricks, etc..
You may even be able to get some ideas of your own from those videos & just run with it, without their tools.
If you decide that's for you, or your game, go for it & have some buddies over you trust to help.
