Status
Not open for further replies.
1 - 2 of 2 Posts
Does anyone know if I can use the Banana plugs that are hooked together. They say they are for posts that are 3/4" apart. Will these work on my 53tx?
Thread Ender
I can't answer for the 53TX. But I can tell you that on the 49TXi you must
use the individual banana plugs, the paired ones are too close together.
I would expect that the other Elite receivers use the same spacing as the
49TXi, but maybe someone else can answer for sure.
Dave
1 - 2 of 2 Posts
Status
