1 - 5 of 5 Posts
Discussion Starter #1
Can someone help me find a speaker stand that is 32” inch tall and top plate big enough for the klipsch 600m?
Found monoprice monolith stands - top plate is 8.5” x 6”. Not sure if this big enough for the 600m. Plus it doesn’t have cable management.
Tried to post a link, but my post count is too low. Google "pyle dual speaker stand."
I went with these, after one of my 600m's took a ride on an older, smaller stand. I don't have any concern of them getting knocked off or over.
The Top Plate doesn't have to be the exact size of the Bookshelf. It can be a bit smaller or a bit larger. That's not important.
Can you explain why you need 32" as that's on the tall side?
Can you tell us how much money you have to spend?
There are Adjustable Stands that are fairly cheap that might work if your budget is low. These are not the prettiest, but they get the job done.
These are very common.
Most stand used in a Living Room or Media Room bring the Tweeter to roughly ear level are stands in the 28" range.
Steve/bluewizard
Premium Member
I use the 24" version of the TransDeco for my Klipsch RP-600M's and it puts the tweeter at 36", just about perfect for my seating arrangement. Good looking with built in cable management. Sanus also makes some nice stands, here are the more expensive steel ones, they also have cheaper options.
https://www.amazon.com/TransDeco-TD32BA-Speaker-Stands-32-Inch/dp/B001PYV7LQ/ref=sr_1_3?dchild=1&keywords=TransDeco+Speaker+Stands&qid=1594831693&sr=8-3
https://www.amazon.com/Sanus-SF30-B1-Foundations-30-inch-Speaker/dp/B0006885FS/ref=sr_1_7?dchild=1&keywords=sanus+Speaker+Stands&qid=1594832329&sr=8-7
Here are ultra heavy duty speaker stands for about $230/pair at 32" -
https://www.audioadvisor.com/prodinfo.asp?number=PGDS400&variation=32
Monoprice makes a lower cost version of the above stands -
https://www.monoprice.com/product?p_id=24794
But 28" is the tallest.
Here is a smaller version with a single Column, for $130/pair at 32" -
https://www.audioadvisor.com/prodinfo.asp?number=PGDS100&variation=32
But I would still like to know your particular circumstance that require a 32" tall Speaker Stand?
And, of course, a Statement of your Budget is helpful.
As I mentioned, if the appearance is OK, the adjustable Monitor Stands are generally low cost -
https://www.zzounds.com/item--GATGFWSPKSM50
https://www.sweetwater.com/store/detail/MonitorStd--on-stage-stands-sms6000-p-studio-monitor-stands-pair
https://www.amazon.com/Pyle-Studio-Monitor-Speaker-Stand/dp/B076X9C7H1/
https://www.amazon.com/Pyle-Speaker-Stand-Black-PSTND35-5/dp/B07PCSQHG9/
Here is another nice looking MonoPrice Stand at 32" -
https://www.monoprice.com/product?p_id=39168
It is hard to make a recommendation when you haven't given us anything to go on.
You have to help us help you by answering our questions.
Steve/bluewizard
1 - 5 of 5 Posts
