1 - 2 of 2 Posts
Premium Member
I have a very small, maybe 5-mm long cut in the foam surround of one of the midrange drivers on a speaker.
Two questions:
1. Would this have any impact on the sound?
2. Is there a way to repair this small cut without either replacing the surround or replacing the driver?
P.S. - The speakers are retail value $5,500 a pair and the driver is a 6.9" driver. The replacement cost (material cost) for a new driver is just over $300.
Thank you.
Mike
Two questions:
Thank you.
Mike
Mike,
You can use super glue to repair the slice, and if you can't live with using glue you can contact me for a replacement driver(under warranty). I think you have Contour s3.4's correct?
Mick
1 - 2 of 2 Posts
