Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I am about to run my speaker cables to the back of the room. Which way is better? Will #2 degrade the signal? '
Choices
1) run through wall to speaker. no plugs/outlets
2) add speaker plug outlet to front & back of room( looks professional)
I like #2 because of the good look of wires connecting to a wall plate instead of going through a hole.
Where can I buy a speaker cable wall plate???
thanks
· Registered
You can use a Blank plate with a hole in it. Speaker wire coming through
a cover on a standard single gang low voltage ring. Both available at the Home Depot. If you want speaker jacks they will mount on the same ring.
Check out some of the sponsors above or Smarthome.com for speaker jacks.
1 - 2 of 2 Posts
Status
