i went thru this same dilemma. from numerous searching and researching of my own, along with the vast amount of knowledge from members on this board, it seems to me the consesus is that standard 14 awg power wire from home depot, lowes, etc will do the trick!! if you choose not to go that route, check out monoprice or other online electrical supply chains. they will sell in bulk quantities.
as for running the wire, i simply stuffed it under the floor board--had to remove some sections to get it under there. this way it is out of sight, out of mind. other options are thru the ceiling, or re-doing walls. hope this helps out and good luck.
-rudy-
-rudy-
