Hey all. I'm finally moving into a house with a perfect room in the basement for a HT. So I'm starting my research. I will most likely have to tear out some of the drywall that is there now and run wiring. So, what speaker wire should I run in-wall? And also what about running RGB component wire to the projector? I assume you all buy stuff on spools, correct? Or do you just buy pre-made lengths of it and adjust as necessary?
Sorry for the n00b question, but I'm just getting started...
-Mike
-Mike
