1 - 9 of 9 Posts
Discussion Starter #1
Hey guys I hooked up my new Polk RTi6s and CSi3 last night to my onkyo 505. They sound great but on some listening modes there is a slight hum. It gets worse as the volume goes up. What could this be and how can I fix it?
T
Discussion Starter #5
I thought it might be a ground loop. I have a power conditioner coming next week which should give me better options when it gets here over my simple walmart power strip. I will wait until it gets here to see if it fixes the problem. if not I will go though the steps to find out what it is.
Any other suggestions
T
Premium Member
I have a pair of Mythos ST powered towers (they are not grounded - two prong), and when they were hooked up to my Onkyo 905, they were silent.
I then hooked up an older but more powerful Parasound, 1206 amp, and while I'm much more pleased with the sound overall, the STs now exhibit a buzz (the buzz level is low and constant, and does NOT increase with volume level)
I disconnected the RCAs from the 905 to the Parasound, and even put a ground cheater on the Parasound to test (and tried a second high quality power cable), but the buzz is consistent. It seems to be eminating from the Parasound itself (not that the 1206 is buzzing - it's not - but the buzz from the STs is coming from the 1206)
Does this sound like something the PSAudio Humbuster would address, or is it more a characteristic of the Parasound that will always be there?
If it doesn't increase with volume then the buzz is most likely internal to the amp...probably low level transformer hum being passed to the speakers. I have experienced this with every toroidal amp design I've had including Parasound. I really don't mind it as long as it is inaudible to me at the listening position...and in fact it is inaudible up to about a foot away.
In my experience bad/failing capacitors can also contribute to hum.
PSAudio is redesigning the Humbuster early this year.
Premium Member
Thanks - if it's a capacitor issue, the Humbuster would not matter, correct?
I would not think so. Leaking/bulging caps in an amp usually are only correctable with replacement. But Cap induced hum will grow louder over time (cap-age) and will most likely vary in intensity during power on/off cycles...meaning it will fade somewhat after warm-up/bleed-off. A cap hum is usually louder than most 60Hz hum in my experience, depending on cap condition. From your description I don't think this is your problem...most likely transformer hum/buzz described on the PSAudio link provided earlier.
1 - 9 of 9 Posts
