I was soldering RCA plugs onto my pre-run speaker wire late last night. Towards the end I had to squeeze into a tight space for one of the final plugs (stupidly left the hard ones till last), anyway, in my tired state I soldered the +ve to the outside and -ve to the centre pin! Now, there is less than a foot of cable to work with, so I am thinking to go to the other end of the cable where there is more slack and switch the wires to match. Would this work? My assumption being that both wires are the same and the +ve marking on one of them is just to help you identify which is which....
