Speakers for proposed AV equipment
894 Views 7 Replies 4 Participants Last post by  4DHD
I need suggestions for a 5.1 Speaker System which will complement the following Yamaha audio equipment:
Receiver: Yamaha RX-V2700
DVD Player: Yamaha DVD-S2700
Any suggestions?
1 - 8 of 8 Posts
A price range would help, and musical tastes.
Between 2K and 3K. Jazz and Rock.
Check out the JBL Studio L Series. The L890s are very good for their price range, as is the entire series.
Here's the link
http://www.jbl.com/home/products/ser...=US&Region=USA
There of lots of options... best bet is to listen for yourself... in the stores or find someone here on the forum that's in your area and has something you're interested in. Local help from forum members is also a great way to get to listen to internet-direct brands before purchasing.
I will give my full endorcement to Swans Diva from The Audio Insider or Oz Home Theater. In your price range you could get:
6.1 Mains ($780/pr BC, $1050 Rosewood)
C3 Center ($330/ea BC, $440/ea Rosewood)
2.1 ($330/pr BC, $450/pr Rosewood) or R3 ($480/pr BC, $650/pr Rosewood) Surrounds
SVS SB12-Plus ($699 Black, $749 Rosewood), PB12-NSD/2 ($899/ea Black), or PB12-Plus ($949/ea Black, $1049/ea Rosewood)
See less See more
THANKS for the suggestions.
My significant other is pressuring me to go with bookshelf speakers so they will blend in more with our home theater furniture.
The furniture has spaces for Front Left & Right speakers, however, the spaces are only 19" high and 21" wide.
Can you recommend a quality 5.1 speaker system whose Front Left & Right speakers would fit in that furniture?
Any of the JBL Studio L series on-wall or bookshelf will fit, except the larger LC2 center.
You could use the LC1 center with two 810s, two 820s, or two 830s across the front. Or go with three 810s or three 830s for the front and any other pairs for the surrounds. Or use five~seven 810s or 830s.
Then add the 8400 sub, if you don't have a sub already.
This series is very good.
Here is that link again.
http://www.jbl.com/home/products/se...y=US&Region=USA
See less See more
1 - 8 of 8 Posts
