So yesterday I go out and audition some speakers and wind up buying the Definitive Technology Procinema 600. They were being driven by a cheap Yamaha and also a marantz for comparison. Both receivers had nuetral settings, I checked.
Took them home, hooked up and ran Audessy on my denon 1909. After experimenting with different settings (Audessy on/off, treble etc.) I am not hearing the crisp upper highs that I heard in the store on more complex audio tracks. I kept the volume under -20 at home although the guy at the store was going up to -7 on the yamaha.
At this point, I am baffled at need some help finding the culprit. My questions are:
1. Could it be the difference in the receivers? Will the denon put out a more nuetral sound than the yamaha?
2. Do the def techs need to go thru the break-in period before they start to display their true potential with the upper highs?
3. I'm awaiting the 12ga. spool of wire from monoprice. I had no choice but to use 18ga. wire yesterday (couldnt just leave em in box on floor!) could this be affecting the sound that much?
The acoustics in my room are pretty good. Pergo floors, concrete ceilings with plaster walls and one large microfiber couch. The room is 10x12x8.
Any input will be greatly appreciated. Thank You
