Will save a long story about why this means a lot to me... But it does.
My mother gave me a 1000 budget, I am ok spending up to 1200-1300
The budget for the 5.1 is about 1000 (rest is for accessories, room treatment and AVR with I am donating an onkyo 805 with a blown HDMI board)
She is not a critical listener but likes music enough to give into the WOW factor if I can make it happen. I am thinking spacious soundstage and clear mids (exagerated might not even be bad.)
Preface Notes:
1. I have 2 DIYSG Fusion-8's she can have for $200 from the budget - Issue is the cetner will cost $300...
2. I have one behringer b2030p she can have for free... I just can't find another one for sale since they are discontinued.
Subs
Was thinking DIY but don't have tools. Can buy a circular saw and made a rip cut jig. Wouldn't count that on the budget (may just round up some small thing ha.)
DIY
Was thinking 2 subs used as speaker stands for the L/R.
Trying to get it down to $400 maybe $500.
1 amp for sure...
Leading candidate is 2xinfinity 1262 ported to 25hz using flat packs.
Issue is...I would either need to give then 125 w each (gross underpower) and still stretch the budget since that will cost about $500 or waaaay raise the budget to $600 and stick her with an nu1000dsp (feels like a bad idea...)
Manufactured
Would certainly be just 1
Maybe SVS used?
My friend has 2 cherry subs - I am almost sure they are PL-200's... Could likely get those for $200
Got tired half way through this and will say more later about speakers...
For now was thinking
Option 1 - fusion 8 L/R, fusion 8 center and 2 jbl lsr305 sides (over budget...)
Option 2 - Arx fronts, JBL lst305 surrounds (WELL over budget...oh and the surrounds need either an amp or built in because they need to be wireless.
Option 3 - 5 x wavecrest audio hlv-1's (in budget!!!)
Option 4 - Used ascend acoustic (ideally 340) LRC, hlv-1 surrounds...
Option 5 - JBL lsr305 x 5
Option 6 - Fusion-6 x 5 (in budget)
As you can see... I am open to anything...
I just want to wow her!
Preface Notes:
Subs
DIY
1 amp for sure...
Manufactured
Maybe SVS used?
