In most cases when the fuse blows on the SPL series subwoofer it is because of some other issue. Replacing the blown fuse often results in blowing another fuse. Still, it is very inexpensive to try replacing the fuse before sending the subwoofer in for repair. The SPL series subwoofer utilizes a 250V, 8amp, 5x20mm, fast blo fuse.
If after swapping the fuse you continue to have problems, I would recommend contacting our product support team at 408-465-2851 (M-F from 7am-4:30pm)
