Congrats on your purchase.....I am sure you will be pleased with the projector....However, you may wish to reconsider on the DVD player....This is an exerpt from a previous thread
Does anyone have any suggestions? I heard good things about the Toshiba SD5700 and SD4700. Are this comparable or better than the Philips?
Reply:
If you want good progressive video you buy RP-56 or if video performance is more important than de-interlacing then you buy RP-91.
Toshiba has chroma bug, bad interlacing and mediocre sound quality. Worst of all - IMHO.
Now, maybe you want to look at your setup and try it first, but if something bugs you or if you see problems, Best Buy should have a 30 day return guarantee.....Maybe by then the RP62/82's might be available.....I was looking into the 4700/5700 Toshiba's myself and this is what I found....
Dave
