1 - 1 of 1 Posts
· Registered
I have successfully used the split function in TMPGEnc Editor 3, where after splitting the frames the software takes you back to the original page and you can click on the edit button for each segment and it will take you to the first frame of where you placed the split. However, using the trial version of TMPGEnc Express, having split the file, when I go back to the original page, no matter which of the frames I click the edit button for, it takes me to the beginning of the entire video! So I have no easy way to see or edit the resultant split video, which is necessary to removed unwanted parts in the middle of a video; i.e., commercials. Any help appreciated!
1 - 1 of 1 Posts
