Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
Has anyone had any experience using the Winegard SquareShooter as an indoor antenna? I'm not talking about in the attic, I mean inside as a replacement for a Silver Sensor. I'm only a few miles from towers, but my Silver Sensor doesn't always do the trick so I was wondeirng if the SquareShooter would work as an "upgraded" indoor antenna. It doesn't look like it is too obnoxiously big to be kept inside, plus it is pretty good looking for an antenna.
-Jeff
· Registered
The SqS has lower gain so it depends on whether your problem is signal level or multipath. There have been a few people using them indoors but only when close to the towers. See if you can buy one from a return-friendly store in your area.
1 - 2 of 2 Posts
Status
