I'd bet what you're hearing is an amp leak. There is a gasket underneath the edge of the amp where it attaches to the side of the cylinder. If that gasket is failing, or if a screw has worked loose over time, the air escaping through the crack can sound like when you blow up a balloon and pull the neck tight as it deflates.
I'd take a shot at tightening each of the screws around the edge of the amp plate. You'll need a square headed screwdriver. Don't overtighten, or you could strip the wood.
As to the grill rattle, I'd give SVS a call and just get a new grill.
Tim
Tim
