I struggled to figure this thing out...
I do a lot of computer networking...and I thought doing the TV stuff would be easy...
Not for me....
The Direct TV dish sat on the roof for about 6 years....we had no issue with Direct TV other than bad
weather....heavy snow etc....we got off Direct TV about 4-5 years ago....And the coax just sat there....had good reception on Direct TV....
Then we went to cable...Then the cable cost went too high...
So we wanted to save some $$$ and stream....
Even though the coax just sat outside in the sun...rain...snow...I didn't think something had gone "bad" with it...
Like CAT5 cables....never any issues with the actual cable itself....
Only after I got a roll of coax with connectors on both ends and tried it did I find the problem....Replaced the coax and
everything has worked beautifully....
What was wrong with the coax....have no idea.....but probably something with one of the connectors...
Glad you got yours working...and actually I'm kinda glad I was not the only living person on the earth with the same issue...
Good luck to you...
Not for me....
Good luck to you...
