Status
Not open for further replies.
1 - 5 of 5 Posts
Premium Member
I want to run two Dish Network feeds into my house, but I only have a single cable run. I don't want to have to lay another cable (I had to dig a long trench initially) all the way to the back of my coach house, where the dishes are.
Is there a way to use a "stacker" or similar technology to combine both feeds into a single RG6 line, then split them out again inside the house?
Thanks in advance,
DC
Unfortunately, stacker technology only works with a single satellite feed. So if you have the AT150 programming package or any of the premium movie packages, you will lose channels. If you have the AT100 programming package, you can stack the feed from the 119 satellite and not lose anything.
-Robert
1 - 5 of 5 Posts
Status
