My first build
Hello all,
I recently purchased a 1950's home. The garage was converted to a game room in the early 80's, planning on using this my home theater. Trying to do as much as I can myself to save money.
The dimensions are 19'x18'x7'10''
The layout is a little strange, there is a laundry area when you first walk in to the left wall. Next to that are two closets. One of them has the hot water heater, the other just shelves on both sides. Also a ceiling attic door near those closets. 2 windows on the following wall.
- My plan is move the laundry appliances to the detached garage. Garage is plumbed/wired for them, just have to convince the wife. Eventually convert this area to a small bar w/kegerator.
- Want to eventually go with tankless water heater, can go into the attic (roof line might be to low for current one). That closet would be for media only.
- Next closet - hold electronics.
- Windows get backout shades or curtains.
I'm in the process of gutting the room. Wood paneling and old sheetrock that has to go.
Here is where I need advice:
Sheetrock: Will have sheetrock professionally installed - is QuietRock worth the extra cost? Trying to keep the budget down but I want to do this right since it's about to be fully gutted - Wondering how much of a difference standard sheetrock w/diy acoustic panels vs QuietRock?
Floor: There is a sub floor under the crappy linoleum tiles, wanted to use carpet tiles. Should I rip up the old tiles or just lay the carpet tiles on them? Any issues laying carpet tiles on a sub floor?
Speakers: So it seems like only layout option is the entry door wall will have screen/front speakers.
Side surrounds on sides obviously(one of them between closets). Will wire for 7.1 even though I have currently have 5.0. The only option for back surrounds should be above the windows? Ideally, where should I wire the sub? Assuming left or right of the left front speaker?
Screen: I would like a 120'-135' 16x9. Do I center the screen with the entire wall or from the left edge to the door frame? Entire walls seems to make the most sense.
Seating: Would like 2 rows of couches, second set on a riser. In a room this size, would a 3rd row be possible? Wanted bar with a few stools for that.
Open areas: The laundry area (bar hopefully) is open, so are the closets - looks like they had accordion doors on them at only point but removed them. Was thinking regular doors for the closet but not sure if I leave the bar open. Seems like a distraction since it would be on the front right side of the viewer. Ideas?
Thanks in advance!
Kub
Hello all,
Thanks in advance!
Kub
