So I've finally made the plunge and ordered my first components for my HTPC. Not much really, just my case and an SSD. but it is finally a step in the right direction.
CASE:
My PC will be in a closet, and cables will be run through the ceiling/walls. so I didn't need an HTPC case. I ended up going with a Cooler Master N200.
It's mATX - has room for 3 3.5'' drives, and 4 2.5'' drives. and looks plain enough that if I ended up using it in the open. it doesn't look super gawdy. That and the case has tonnes of fan space for higher airflow.
OS Drive / Media Storage:
And I've picked up an ADATA SSD 64gb, for the OS. I managed to get both for 105$can , minus a 25 dollar mail in rebate. So got the case and SSD for ~80 bucks plus shipping and taxes. Not a bad start.and for storage, was thinking of going with two - 3tb hard drives in a raid. so 6tb of media space. and I've got a couple 500gb 2.5'' laptop hard drives kicking around, I'm going to put in for steam/games to run off of.
CPU:
As far as the rest of the build goes. I could use a bit of help.
I'm thinking either an i3-4130 or i3-4130t. Originally was leaning towards the 4130t, for lower power consumption. But as I'm going to have this as an 80%htpc, and 20% steambox. I was wondering if anyone thinks the 4130 or even 4330 might be better suited as a CPU.
PSU:
Power Supply I'm completely stuck on, I want something efficient, but isn't going to break the bank.
MOBO:
I'm going with a mATX board. thinking an H87 board so I can upgrade ram down the road more easily, and have an optical audio out. - still haven't decided fully on which one. but am thinking of http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131994
RAM:
RAM I'm going to wait and hope prices come down from this ridiculous high they're on.
Blu Ray:
Blu ray drive - TBD
as of now, I'm just going to run with the onboard graphics in the i3. then upgrade down the road for dedicated graphics for the gaming side of things.
So does this sound like a decent build? for a low end - htpc/steambox. if anyone has some pointers, ideas, or advice I would love to hear it.
CASE:
CPU:
PSU:
MOBO:
RAM:
Blu Ray:
Blu ray drive - TBD
