hello
i'm a newbie and will say hello to all users here.
my 1272 powered down by itself after about ten minutes. then it would only power up for a second and shut itself down. the error code was 0A. 24 hours later it has been running OK for 2 an hour so far. now the 0A again after 1/2 second.
some times i have the 02 code (when stop after 1 second) or 08 (when stop after 2 second)
i did the reset at the Y board (power on, standby) switch 1 off, then press the reset button for about 5 sec., switch 1 back to on.
i have the same error as before.
i saw the same question 2 years ago, but at the end of the tread it will no say what is was.
did i the reset correct? (here are different answer about the reset)
is there a place where i can find the repair manual or other stuff like that.
i can use any information.
thanks
tom
sony 1272
switzerland
thanks
tom
sony 1272
switzerland
