1441 - 1460 of 1609 Posts
Ok I don't knw why haven't thought of this before smh but I tried the same Netflix content on my Panny ub820 dolby vision cinema default 50 brightness and the 2 shows which I really saw this was ozark latest season episode 1 and the Witcher both during the beginning of the episodes. ozark has got some strange Pixelated stuff happening on the internal app and on the panny player. Its like a checkerboard of lines or something so that leads me to believe its the show itself and the Witcher well it was jet black on the panny at default 50 but 2 percent gray like on the internal app so that makes me think it's something wrong wit the Netflix internal app on the lg cx
I just tried this test on my cx and I've always had to put brightness on 49 but using this test I see every number flash at default 50 but soon as I put it on 49 black crush all the way to 82 ie no flashing at all lol I wonder what is causing the raised blacks at Default 50 when using the test its correct but watching content u can see the raised blacks on Netflix via internal app or even gaming on some things and 49 seems to correct those things for example when starting a netflix show the bright N in the beginning of every Netflix show is like a 2 percent gray at Default 50 but 49 has it pitch black its annoying!! Lololol
According the CX thread, there is currently an issue with DV glow with brightness at 50 on your tv and LG is looking into it.
https://www.avsforum.com/forum/40-oled-technology-flat-panels-general/3119288-2020-lg-oled-cx-gx-owner-s-thread-faq-posts-1-6-no-price-talk.html#post59163024
It's definitely mostly a Netflix thing, like how the opening credits of Mute are grey again when they used to be full black. Might have something to do with the movies being encoded with an old DV version not playing well with LG's updated library on their TVs. With DV, who knows.
I only really notice it with Netflix though. Vudu, Movies Anywhere, etc. seem fine.
Yea I was thinking it was Netflix as well but a highly respected calibrator said that lg was able to reproduce the issue on the cx and are working on a firmware so hopefully that firmware does fix it whenever or if it ever comes lol
I thought that was a separate CX issue.
The Netflix blacks thing is more than just a glow on the opening credits of Mute with the internal app.
Can we assume the firmware fix would apply to the 2019 series of LGs too?
That I don't know. I find it odd that on the 2019 and 2020 models, they both have the DV issue, while on the older tv's 2016-2018, it does not exist. If the issue occurs on the 2019 model, and they could not figure out how to fix the problem before the 2020 models came out, that would worry me. Either the DV profile they are using is defective, or the chip design is.
I went with the LG CX after the hot mess Dolby Vision HDMI implementation from the Sony sets but now there are different issues on LGs? Dolby Vision just seems like a mess in general. wouldn't HDR10 with whatever the manufacturers own flavor of tone mapping be preferred at this point?
The benefit of the newer OLED's such as you have, do better tone mapping of HDR10 than the older tv's such as my E6. HDR10 on my E6 is not all that good, whereas DV is superior. That gap with the new tv's has narrowed considerably, and you probably would not be able to tell much difference, although DV would still be better with scene by scene tone mapping.
welp finally noticed raised blacks when viewing DV content from Apple TV 4K on my LG CX. bumped brightness down to 49 as the bandaid. between dim garbage DV on Sonys and these quirks with LG and I’m about ready to swear off Dolby Vision forever
I have no raised blacks or glow on the internal netflix app, only on my ATV4K, but i don't use it for netflix.
Do we need to have Dynamic tone mapping on for HDR10 then?
I turned it off when I noticed it was on by default.
I just got a B9 a few days ago. I love the tv, but I have noticed the raised blacks. I tested the first episode of The Haunting of Hill House. The first couple minutes I noticed the not fully black bars. I tried forcing HDR10, but I still get the raised blacks issue in the bars. Is it because HDR10 is borked as well or because that particular show is really only available in DV or something?
For now, I’m just watching everything in SDR. It looks stunning and miles better than my previous tv.
I’m using the Apple TV 4K
Try watching the same scenes via the Netflix app on the tv. If you don't see it there with DV, then you will know it's not your tv, but the ATV
It's not just DV, HDR has raised blacks occurring when a custom 1DLUT is applied through calibration. Apparently LG is investigating, but this has been going on since last fall.
Sent from my SM-N975U using Tapatalk
Ok, so I now know how Apple can fix this:
Apple is using Dolby Vision profile 5, which means that the processing is done in the Apple TV 4K itself. The LG OLEDS work perfect when the processing is done in the tv (because of the dedicated DV chips inside them), that's why Dolby Vision content on discs and in the internal tv apps are perfect. Much brighter image and free of elevated black levels. Apple should give the users this option in tvOS, just like users can do on their Oppo 203 bluray players. This would fix this problem once and for all and to me it seems a simple fix.
I've presented this solution to Apple, let's hope that they take note. It's been taking too long now.
I really want to get this device again. I just want to know for sure if they will fix it or not. I have heard that they have fixed problems with older OLED’s, so is there hope this gets fixed as well?
My solution described above will fix the issue for all LG oleds all the way back to the 2016 models.
