1601 - 1620 of 1623 Posts
So I use a Philips Hue Sync Box between my OLED and my AVR for use with my hue lights which sync with the colors of the content on screen. The box received an updated recently with Dolby Vision support and now the elevated blacks will are gone. The box can be configured with an accompanying app where the user can select how the Dolby Vision content is processed. On the player or on the tv.
Happy to inform that the elevated blacks are gone. The picture is now comparable with the DV in the internal apps of the tv.
Which setting got rid of the elevated blacks problem player or tv?
Noticed the letterbox bars on the Jurassic World demo clip on the Dolby Vision internal app are noticeably above black on my C7.
heh
heh
I can see it in the JW demo as well as the Skyscraper demo. It's barely noticeable on my C7, but distractingly blatant on my CX. I don't see it at all on my C9. I don't see elevated black on any DV content from my Oppo 203 on any of them.
Standard Range and HDR/HDR10 content look perfect to me on the AppleTV 4K. All content (including Dolby Vision) looks perfect on internal apps and nvidia Shield.
But, Dolby Vision on 65C8 is the issue. Noticed the issue constantly watching "Greyhound" (new Tom Hanks WWII naval movie) which is an AppleTV exclusive. Every time the movie would fade to a black screen (which was often). . . there was visible glow. Of course, as said prior, you need to be in a fully dark room or your eyes won't be able to detect.
--H
I see this on the C8 as well for all Dolby Vision content whether I'm watching content from an internal app or from my Panasonic 820 UHD Blu-ray player.
If the letterbox bars remain inky black, but blacks between the letterbox bars are elevated at times, then there is nothing wrong with the tv. You are accurately seeing the DV content the way it was encoded. Now if the letterbox bars are elevated with DV content like I see only on the ATV4K on my E6, then it's the ATV4K. I have no elevated blacks with internal apps or via my OPPO 203 or Panasonic 9000 UHD players.
For what it’s worth I don’t see the same elevated/glowing blacks if I play the same scene in HDR10 (one good example is the overture that opens 2001:A Space Odyssey). I would not expect a completely black scene to differ that much or at all between Dolby Vision and HDR10.
I don’t have another TV that can playback any HDR formats to see if it also has that big of a difference between Dolby Vision and HDR10.
Reading through some of the comments it seems the raised black issue only occurs in streaming apps and media boxes? Does playing 4k UHD disc or gaming exhibit the same issue too? Also does the issue affect LG CX too?
I have no issues with UHD discs in DV on my E6. I do believe the CX does have an issue with elevated blacks with all DV, including discs. LG was aware of the issue and was going to send out a fix. Whether that has happened, I do not know. Those in the CX thread may have more info on that.
I see, thanks. I might just have to disable DV altogether then since I'm content with HDR10 anyway.
Unfortunately, I must confirm that the new TvOS 14.0 did NOT solve the raised blacks in DV via Apple 4k box on the LG C9
Now I am definitevely sure that the issue will not ever be solved.
So IMHO this is Apple issue as Nvidia when they activated G-sync (VRR of HDMI 2.1 on 2.0b) on Lg c9 had the same issue in HDR only, ten they fixed it almost immidiately. Dunno about Dolby Vision, but it is also supported. Somebody should check. Works in Netflix and Mass Effect Andromeda on Windows 10 1909 at least (1703 introduced it and then the broke it).
Same thing on my E6. Guess we will have to wait for a new ATV box to see if they fix it with hardware.
I'm going to get an OLED TV this fall, and keep going back and forth between the LG and the Sony. I don't game, and I prefer the Android TV interface, but I'm really hung up on the fact that I can get the LG through Costco and have warranty for much longer. I think up to 6 or 7 years with my Costco Visa, and it's generally a little cheaper than the Sony so I'd just get a Shield TV maybe.
But this raised blacks thing has me concerned, and while I've been reading this thread, I'm hoping for a little clarification...
- This affects just the LG, not the Sony?
- Is this just for Dolby Vision? Is HDR10 fine? Is there an option in the TV to display HDR10 instead of Dolby Vision? So far my experience with Dolby Vision on my Vizio LCD is pretty much a hot mess. Super dark and muddled picture in any dark-ish scenes, and whether it's director's intent or not, I find HDR10 much more pleasing. Dolby Vision just ends up being too much work to watch.
- Is this just for Apple TV? Are internal apps or other devices like the Shield ok? I am using an Apple TV with my current LCD, and that may be contributing to my Dolby Vision issues there as well, although it's not much better through the TV apps.
- What are people doing to deal with it? Just not watching Dolby Vision, or changing settings? I wouldn't want to get it if I'm unsatisfied waiting for an update that might not ever come. Most of my viewing is 4K/HDR content on Netflix, Prime, etc, and some standard streaming on HBO, Hulu and ESPN. I watch enough streaming content that would be in Dolby Vision or HDR that if its a problem it would bother me.
There are different issues. The 2020 LG models have issues with all DV, no matter the source. The blacks are elevated. LG said they are working on it. Months have gone by, and still no fix, which tells me the issue is not easy to fix. On older LG models, the DV issue is just with the ATV4K.
I have a C7 and it has elevated blacks with all DV content from all sources, including internal apps. Brightness 49 fixes it but makes it far too dark overall. When I say elevated I mean visible only in a completely dark room.
Cheers
I thought that such a topic did not exist in any forum, I explained my problem with DV in the oled B7 topic, but I see that I was wrong and it was that I expressed it here
I use 2 oled B7, one has the update [05.80.55] and the other is only until the update [04.70.75], both have the ASBL deactivated and both using in CINEMA (User) and everything else OFF
Why is the other one not updated until [05.80.55]?, you will see in my memory this was approx almost 9 months ago approx, until more or less that time it was that the Dolby Vision watching Netflix, was or had an incredible image, with a lot of depth and deep black levels, at that time both oled B7 had the update [04.70.75], therefore both looked identical in DV in the same contents and I tell you because I have seen the same movies in the dark on both tvs with the same update [04.70.75], so far everything was fine and 10/10 with the Netflix DV image
at that time I was able to see 3 movies that helped me to have some tips on how I could approximately evaluate the depth or not have black loss in DV
these were:
  • the curse of hill house
  • story of a marriage
The latter has the peculiarity that when the film begins, the title appears, which is like a cream color (story of a marriage) and it fades into black on the entire screen with the title of the film, immediately on that black background it appears Yes, Johanson and even when she appears submerged in a total black background, then she advances and there she just begins to attenuate the image, that is the way or a tip of when DV is perfect, at least for me, another is that the same the depth that was exhibited was incredible
but this changed when I updated one of the b7s to [05.80.55], a few days later I realized that the Cinema mode (user) was not the same
In the B7 that still had the update [04.70.75] it still maintained the same depth and the correct black level, but in the other B7 not anymore, so I tried to inform myself about the issue without much luck, now I just found out about this issue and share my experience
then continued
I have an LG CX55. I've compared multiple scenes that have perfect blacks on HDR10 but not Dolby Vision. Lowering contrast from 100 to 99 fixes the elevated black and has a next to imperceptible effect on the rest of the image. I've only been watching files off the USB, the TV has no inbuilt option to revert to HDR10 when DV is detected. But certain apps or players might give you the ability to choose, not sure.
I have asked before elsewhere and got a wide range of answers on this but like, how much of an issue are the raised blacks in Dolby Vision on the CX (and as I understand it, in VRR for gaming)? Is it super noticeable? Do the blacks look grey all the time? Or is just a pretty minor thing? I guess I understand what the problem is, but not really how big of a problem it is? Is it enough of an issue that, assuming it is never fixed, I should just hold off for next year's model, or is just not that big a deal?
personally I don't think its a deal breaker, its only really noticeable if you are looking for it and you're in a very dark room
Thanks. I ended up getting the Sony last week when it went on sale. I do watch in a dark room almost exclusively, and don't game at all, so I decided the raised blacks weren't a compromise I needed to live with, especially with that price. The main thing that really drew me about the CX was the long warranty I could have gotten from Costco, but I'll live.
