I just got royally scr*wed when I bought a Silverstone LC10M. The product, it turns out, is basically useless for HTPC as shipped.
Anyone who is the least bit serious about Home Theatre knows that a dark evironment is essential. I have a CRT projector for best image Q and have spent much time and money creating a good viewing room that is almost completely dark.
Like most reasonably advanced Home Theater users I have also gotten a nice universal remote that can handle all my products and is capable displaying user designed menus macros and such. Of course it is also backlit to that I can use it in my viewing room.
Now, the new iMON devices (wethered bundled with a case like Silverstone or not) can ONLY use the bundled iMON PAD remote. NO remote can learn its codes according to SoundGraph/iMON. The reason according to them is that a unique code (that they will not let their customers know the specs of) was needed for good mouse simulation.
For a Home Theatre user that is a step back into the dark ages.
First of all – having to have a low budget extra remote to be able to use your most common controls (like DVD controls) makes HT-people itch (especially the ones who have spent 2.000 on a top line device like a Pronto).
And to make matters worse – even if you could live with that (which I find very hard) – you still can’t use this product in a half decent Home Theater, since it is not lit in any way shape or form. It’s black…
Now I’m really in the **** since changing the VFD/remote in the system will be expensive and tricky. I just want EVERYONE who is even thinking about iMON, a Silverstone case or any other HTPC case that comes bundled with iMON to be aware of this.
SoundGraph says market research showed that non-HTPC users who are also important to them wanted better mouse function. My reply to that was that if their target customers weren’t HTPC-users like myself, they should probably stop using blown up catch phrases such as: “Universal IR Remote Control Device for Home Theatre PC†and “New Standard for Home Theater PC†all over their home page. They might also think about NOT bundling their products with dedicated HTPC cases like the Silverstone LC10M that I got. That would save their customers a lot of worries, time and money.
I suggested a clear disclaimer reading: “WILL ONLY WORK WITH BUNDLED NON-BACKLIT REMOTE - NOT FOR USE IN DARK ENVIRONMENTS SUCH AS HOME THEATRES!â€, instead.
I will now contact Silverstone and try to find out how they propose I should use this product in an HTPC environment.
