My question relates to how STB aspect ratio control integrates with the RPTV aspect ratio control options.
Most STB today offer numerous aspect ratio control options - normal, full, zoom, panorama, etc. Most RPTV also offer similar options. Which unit, if any, overrides the other? If you want to control the aspect ratio via the STB, what aspect ratio should the RPTV be set to? If you want to use the aspect ratio control options via the RPTV, what aspect ratio should the STB be set to?
Also, if you use the STB to control the displayed aspect ratio, what screens are used in the RPTV? The reason I ask is that if you were to get your RPTV calibrated by an ISF professional, would you only have to converge one screen (e.g. full) as opposed to converging each screen you would use had the RPTV been used to control aspect ratio?
Anthony
Anthony
