Status
Not open for further replies.
1 - 3 of 3 Posts
If you have this set, what STB are you using to get HD programming? I've tried the Toshiba and loved it, but had the video dropouts that Sony couldn't fix, said it was a compatibility problem. I then bought the Sony and had the Lip Sync problems, very poor OTA HD reception, and did I mention Lip Sync problems? Thanks so much.
i have the 61hs10, and am using the mitsu. HD-400 box.
i don't notice any problems with it, other than that it's a little dark.
to be fair, i am barely using it right now. i haven't been home during primetime much recently, and when i am, well, it's hockey season.
dinesh
DVI/HDCP sucks. DFAST sucks. Boycott JVC.
I'm using the HD100 with my 61HS10. Those of us in the NYC area have not had any lip sync problems well I dont anyway. I guess we are lucky http://www.avsforum.com/ubb/smile.gif Other than the 30min guide update dropouts( which can be avoided) I love the way this STB works with my HS10. I know this does not help you out but I thought I'd respond.
SAT-HD100 KP-61HS10 STR-V444ES DVP-S9000ES
1 - 3 of 3 Posts
Status
