Has anyone had experience with the Steren 5x8 multi-switch? A search of the AVSforum found no hits.
From the product description (below) it appears to be cascadeable and compatiable with the new phase 3 dishes. Are my assumptions correct?
"New generation DBS systems view and receive signals from satellites in multiple orbital locations to provide HDTV programming and local-to-local television programming. These multi-switches take the signals from two dual LNBs and the signal from an off-air antenna or cable television and distribute to up to eight satellite receivers. Satellite and off-air signals are separated at the DSS receiver using a diplexer."
Compared to the Terk BMS58, it appear not to have as rugged wx-proof t housing, but that's not a factor big factor, since I am planning to mount it indoors. The Steren is about $20 cheaper and more online merchants have it in stock.
I am also considering the Terk BMS58, but haven't found it in-stock.
Also are diplexers from different manufactures interoperable? If I buy the Terk MS must I buy the Terk Diplexers which are more expensive?
Alan
Northern Virgina
Alan
Northern Virgina
