Status
Not open for further replies.
1 - 2 of 2 Posts
Hi guys,
I'm having trouble getting ProLogic signals out from my WinTV card to my external ProLogic decoder.
Sky Digibox SCART2 (Composite) -> WinTV Composite (through DIN)
Sky Digibox SCART2 (Audio) -> WinTV Line input
WinTV audio output -> ALC650/SB51 Line in (with system in 2ch mode to enable input)
ALC650/SB51 SPDIF Output -> Yamaha DSP-A1 decoder DVD Optical In
ALC650/SB51 Front Stereo Output -> Yamaha DSP-A1 decoder V-Aux analog In
AC3 works fine, and sounds great.
If I select a ProLogic channel on a DVD, it also works fine.
If I'm watching a NICAM ProLogic TV channel, and the decoder is set to ProLogic decode it seems to spread the Center channel out over the front 2 speakers, and creates a nasty echo.
If I turn ProLogic decode off on the amp, I get good stereo sound.
Any suggestions on how to get ProLogic working?
Andy.
(WinXP, Hauppauge WinTV FM, ALC650 chip on motherboard)
Discussion Starter · #2 ·
Update - For some reason running AudioSel seems to improve the situation. I can now get ProLogic decode working as expected. Must be some registry or driver tweak that audiosel is making.
1 - 2 of 2 Posts
Status
