Let me preface this by saying that I understand the bass becomes non-directional below 60-80 Hz.
Do any receivers output stereo bass via the 2 sub outs (i.e. 7.2, 9.2) while in the stereo output mode, or will they only play a single LFE signal (which is what I have found to be the case for most receivers)?
subsequent note and question: if you get to choose the crossover point for the sub via the receiver, then I would assume the receiver just sums the L and R LF signals to produce the sub signal... so why not just use two crossovers to maintain stereo LF while in stereo mode?
I want a multichannel receiver/amp, but I will mostly use it for playing music. Can anyone recommend a receiver that outputs a low-level stereo sub signal? If "no", can anyone describe a workaround?
-Dan
-Dan
