Folks,
I live in Sterling, VA (right off Church Rd). I am planning to buy the 60'' Sony XBR TV TODAY and would like to make sure that it is worth the extra $1500 vs the GWIII. Have you yet used/setup the built-in HDTV tuner for receiving broadcasts yet? If yes, how was the experience? I am planning to buy the TV and am wondering the use of the tuner. If you are using the tuner,
1. Which city are u from?
2. How is the reception/clarity of the channels?
3. How did you install it?
4. Can I get away with an indoor antenna?
5. If installed in attic, how can I run cables to my basement?
The above info shall help me make the decision. I am wondering how well it shall work in this area and also how difficult would it be to set it up myself.
