Status
Not open for further replies.
1 - 6 of 6 Posts
Is there any info for the low voltage control option that came with a stewart model a I purchased used? I'm looking for data on the RF connector and IR connector and what signals that is looking for.
I am looking for a way to control with one relay or one trigger. As in on and it's down, off and it's back up.
I don't see how to do that with the switch inputs.
thanks
Troy
Discussion Starter · #3 ·
Yes but I can't find info on the controller, only the screen itself or marketing hype.
I doubt they would list protocol and voltage levels for those connectors anyway. (I had hoped maybe one was rs232 or something.)
Maybe I should have just asked how to get a stewart electriscreen to operate off of a projector trigger output. Either that or maybe I should add some type of serial control relays for the HTPC as I already run girder anyway...
Any ideas welcome.
It's not automated when you have to stand up and hit a button on the wall.
thanks for replying...
Troy
pcCinema;
I understand you have only the control box but no IR receiver, which you now try to mimic, correct? I have an Electriscreen (with IR remote). To install the IR option, I simply had to plug the cable of the IR receiver, which came with the screen, into the control box.
I just checked the manual of my Electriscreen (with IR remote): spec.-wise nothing really useful, sorry.
Have you tried contacting StewartFilmscreen directly? So far all my dealings with them have been more than pleasant. I am sure they are more than happy to help you.
_____
Axel
1 - 6 of 6 Posts
Status
