Hello guys I have been researching a lot about my issue and when I thought I had the answer the guy at my local Radioshack said that it wouldn't work so here it goes. I just got the Sony DN1000 to replace an old receiver and decided to keep my speakers, so everything worked fine the problem is the with the subwoofer. The one I got is the Sony SS-wp700, which has speaker wire to connect to the receiver, and the DN1000 has an RCA output to connect the SW so I went and bought the RCA cable with speaker wire on the other end just to find that it doesn't work that way so I kept researching and I found something similar, here in the forum, that you need a speaker-level to line-level converter in order to work. So I went to radioshack again to see if they had something like that and the guy told that they didn't and that only works on car stereo and suggested me to buy an amp to connect the SW. So here's my question is this correct do I need an amp instead of the converter to connect the SW?
Thanks in advance.
