How high is the Master Volume settings on each of the AVRs..
The Onkyo 502 and HK 135 are entry level AVRs..
Both have limited power power output..
It sounds like your AVR playback level is too high...
And the amplifier is clipping slightly..
Also try to keep the center Channel trim setting at a more conservative setting.. In a couple of test reports for the Athena..
I noted that its impedance and sensitivity specs are on the low side..
Such as 4 Ohms and 85dB..
My recommendation would be to go to a higher powered AVR..
Just my $.02 worth...
