Status
Not open for further replies.
1 - 2 of 2 Posts
I have the Windows XP Media Centre PC with the ATI X300LS
video card. I have a Pioneer PDP-5040HD plasma display connected to it.
When the computer boots up the display comes perfectly fine as expected.
Plasma has 4 inputs, and the HTPC is connected to input 3.
But if I change the input on the plasma ( to check what is on TV connected to input 1 ) and come back to input 3, my screen is blank.
I tried hours to overcome this problem without any result.
Please help me if you can at least give pointers to the solution.
Thanks a lot
--nw
Thanks a lot
--nw
Norris,
I had the same problem when I updated my ATI card driver to Cat 5.8. I could restore the DVI signal if I disconnected the DVI cable and reconnected. I fixed the problem by installing ATI Cat 5.4 drivers.
1 - 2 of 2 Posts
Status
