OK I have a file that is encoded in H.264. CoreAVC (1.2.0.0) is installed and I am using MPC 6.4.9.0. Other H.264 encoded files will open just fine in the player. Properties show up like this when I right click on the files that work:
Video: MPEG4 Video (H264) 1920x1088 [Video]
Audio: Dolby AC3 48000Hz stereo 384Kbps [Audio]
Subtitle: DVD Subpicture [Subtitle]
Now this problem file only shows the Audio stream when I open it in MPC and check properties. No Video or Subtitle shows up for it. Naturally all I get is audio and no video from the file.
Here is where it gets strange. If I open the problem file in Windows Media Player it plays fine. If I check the properties of the file while in WMP it shows the video codec as CoreAVC just like it should.
Why would MPC have a problem with this particular file but none other? And why would WMP work fine with it?
