I am having trouble receiving channels that are on the same heading & distance as ones where I get a strong signal strength.
I am using a TivoHD and Tivo series 3 HD unit to receive my local channels. The previous owner of my house installed a physically large directional antenna in the attic (brand or type is unknown) and it is pointed in the correct direction. There is about a 30' run to a PDI-brand 2:1 splitter and then 30'+ of additional coax to the nearest Tivo (other leg of the splitter is probably 50-60'. Below is a cut-and-paste from antennaweb. Channel 8.1 comes in @ a strength of 99, channel 42 @ ~50 and channel 2.1 comes in @ 0. Will an amp like a Channelmaster 7778 allow me to pull in the weaker channels (without breaking channel 8.1) or is it more likely that I'm having multi-path problems (since the towers are all in ~ the same place)? In general, VHF is doing much better than UHF channels.
DTV Antenna
Type Call Sign Channel Network City, State Live Date Compass Heading Miles From RF Channel
uhf KUNP-LP 47 UNI LA GRANDE, OR 82° 11.6 47
uhf KATU-DT 2.1 ABC PORTLAND, OR 83° 12.1 43
vhf KGW-DT 8.1 NBC PORTLAND, OR 81° 11.5 8
uhf KPXG-LD 42.1 ION SALEM, OR 81° 11.5 42
uhf KEVE-LD 36.1 TBN VANCOUVER, WA 82° 11.6 36
uhf KWVT-LD 17.1 A1 Salem, OR 81° 11.2 16
uhf KPXG-DT 22.1 ION SALEM, OR 81° 11.5 22
uhf KOIN-DT 6.1 CBS PORTLAND, OR 83° 12.2 40
uhf KRCW-DT 32.1 CW SALEM, OR 83° 12.2 33
vhf KPTV-DT 12.1 FOX PORTLAND, OR 82° 11.4 12
vhf KOPB-DT 10.1 PBS PORTLAND, OR 81° 11.5 10
uhf KPDX-DT 49.1 MNT VANCOUVER, WA 82° 11.4 30
DTV Antenna
