Status
Not open for further replies.
1 - 5 of 5 Posts
This may sound a little nuts:
Over the last few nights I have been noticing that one of my UTV recievers is logging onto my msn account in the middle of the night. I decided to see if was doing a download for an upgrade or something; since it usually will say what it is doing. Instead I found that it was just logging on to my home page for MSN. It's very odd as it just sits there. I work late hours and haven't seen this happen, except for software upgrades.
Any thoughts?
Carl
Hi,
You might check to see if you have any "auto dial" settings selected.
I don't use my MSNTV account much so I'm not sure where to look... But I've heard you can set your WebTV/MSNTV (UTV) to auto check e-mail and such...
If your UTV seems to work normal in every other way I'd suspect a setting issue.
Good Luck,
Discussion Starter · #3 ·
Thanks for the response.
I just went through all my menus to look for an auto dial and can't seem to find anything. We have the Sony UTV recievers. Do you know where to look exactly?
Carl
Discussion Starter · #5 ·
You were correct. I logged on and found a setting for check emails at 3am. I just can figure out why I have never seen this before. Perhaps I toggled it accidently.
Thanks again.
Carl
1 - 5 of 5 Posts
Status
