Hey all,
Sorry if this is the wrong forum to ask this but it seems an odd question to fit in any of the forums.
I have a DVD player with HDMI out as well as TOS out. I currently use a 2.1 receiver (HK 3490) for the audio, using the TOSLink and send the video over the HDMI to my TV. Everything is great with one exception. The DVD player sends the audio out over both the TOS link and the HDMI port so I get audio out of my TV as well as my receiver. This is an issue not only because the TV's built in speakers are crap, but also there is a subtle but very perceptable phase shift between the two audio sources. To fix this, I have to go into the TV's menu hierarchy and disable the TV's speakers. I do however use the TV's speakers for watching TV (I really don't care about TV sound quality). This is a pain as I have to then go back and re-enable the TV's built in speakers. Sadly, there is no button on the remote to switch between the two options (I've looked into using my harmony 900 to do this but it really doesn't do macros).
So, to make a long story short, is there any way to strip out the audio from the HDMI interface so I can only get audio out the TOS link? There's nothing in the DVD player to manage this and it only has a single HDMI out for video (no DVI out). If it requires a separate device to do this, I don't want to spend more then $50 bucks. Any more then that and I may as well replace the DVD player.
--Brett
--Brett
