I'm presently framing my basement and plan on using the PARADIGM AMS-LCR's for the home theater, can you tell me what distance i should space my studs at? (studs are 2x6)
Left and Right will be placed vertically and the center will be placed horizontally under the screen
The specs for the speakers are as follows
Diameter or Height x Width
61.3 cm x 15.4 cm
24-1/8 in x 6-1/16 in
Minimum Mounting Depth
6.7 cm
2-3/4 in
Cutout Dimensions:
58.7 cm x 13 cm
23-1/8 in x 5-1/8 in
Minimum Internal Volume Required 16 L
0.57 cu ft
thanks
61.3 cm x 15.4 cm
6.7 cm
2-3/4 in
Cutout Dimensions:
58.7 cm x 13 cm
0.57 cu ft
thanks
