If your receiver has no pre-outputs, you can’t use active speakers with it.
Wayne A. Pflughaupt
Wayne A. Pflughaupt
I am not sure I understand what you are planning. Do you want to use the receiver for producing, i.e. mixing in surround, or for passive listening to finished (surround) mixes?Good Evening audio experts,
I will start with saying that I am an amateur in the subject. I plan to buy a pair of active studio speakers for guitar playing and recording. The input would be Line6 HX Stomp effect processor and amp modeller. As I also own a receiver (wow!) I would like to use those monitors for surround system as I also have some passive speakers I can use.
So the question is. Is it possible to have a "box" with two inputs , one for a receiver and one for Stomp and output going to speakers and a switch so I can swap between the two ? Does device like that exist ? Also there would have to be some kind of converter between the receiver
and monitors. My receiver is Yamaha RX-V475 and it doesn't have the RCA pre-out (I believe thats what you use to connect receiver to active speaker or subwoofer).
Thank you for any advice and suggestions.
Cheers
How about an adapter like this one i.e. "Russound ADP-1.2 Speaker-level to Line-level Adapter" ? (sorry cant post links yet)If your receiver has no pre-outputs, you can’t use active speakers with it.
HI Skinfax1, thanks for response.
I want to be able to switch those speakers between receiver - for home theater use - and guitar processor. Therefore wondered whether there is an interface I can use to switch between the inputs.
Thanks Skinfax,So you want active studio speakers exclusively for playing guitar through a hardware FX? Why not a guitar amp?
In case you want to write your own songs, maybe at a later time, then an ITB (in the box = software) solution seems to be the better solution than a hardware stomp fx.
