Let's say your custom built door arrived and the day before it is to be picked up and installed, you get a gut feeling to go check it and make sure everything is correct before the installer picks it up. Then lets say you get there and sure enough, it's a left hand door and you ordered a right hand door.
You can't "fix" that can you? I have a feeling I'll be waiting another month for the replacement. Am I right?
