Ok, so I finally need to replace the bedroom TV and I've tried to do some searching, but alas I have run a little out of touch with current HDTV kit when it comes to what to look for and pricing. It's a little hectic at work right now (tax season is getting in full swing) and I can't lie I am a little exhausted when I do have the downtime.
Basically I would prefer about 40inches (it would be hard to go much smaller seeing as it would be replacing a similar sized set) and I would just like to know what the gurus at AVS Forum think is the best set I could get for in the 500 or under range. I would greatly appreciate any input at all that could make this go a little easier, sorry if this comes off as needy or too general of a question or if it offends anyone, I'm just looking to get the best bang for my buck, and I couldn't really think of a better place to ask.
Although this is the LCD forum, I've never had a preference between LCD or Plasma. I think it would be a little a-holey to post in both forums though, and from memory quality Plasmas always seemed to be priced higher than LCD/LED televisions. Smart TV isn't a must as I have a Roku/Chromecast that I can hook up, but I will never argue with one less input device in my bedroom.
Again, any help at all would be greatly appreciated, thanks for your time.
