Did you perform the "sub crawl" test to find your current sub location? Do you have REW setup so that you can take measurements? Your MLP could be in a null. Do you know what input voltage your amp needs to have in order to output 500w?
I looked up the manual online. The dip switches should be set for bridge mode, not parallel mode. Use input and gain for channel 1.
Input sensitivity is 1.15v on that amp, shouldn’t be a problem. I assume your old sub was working with those receiver settings?
My father runs a pair of HT18’s on 600w audiosource amps and they work well.
Chris
Is your 1/4" adapter a TS or a TRS? This one bit me. Make sure it's TS.
Joseph
How have you wired the speakOn plug? The amp end should be wired to 1+ and 2+.
Where do you have the filter set?
^ see above. Take a picture or post a link of the 1/4" adapter being used.
I posted a pic of the manual in my first post, but here is a comparison showing both options.I looked up the manual online. The dip switches should be set for bridge mode, not parallel mode. Use input and gain for channel 1.
Input sensitivity is 1.15v on that amp, shouldn’️t be a problem. I assume your old sub was working with those receiver settings?
My father runs a pair of HT18’️s on 600w audiosource amps and they work well.
Chris
I think you’️re mistaken or maybe I am, my understanding is that you have to put the dip switches in parallel mode so that the L and R inputs are combined as a single input. Do you disagree? At any rate, I can give it a shot changing it and report back.
Ahh, gotcha. Should be good to go with that setting.Sorry should’️ve looked and explained better. In the bridged pic you can see dips 4,5,6,7 al in the right position. 4 and 5 in the right position is for parallel inputs. If they were in the left position the inputs would be in stereo.
Really doesn't matter, you're going from unbalanced to balanced either way. I've had good luck with Monoprice's RCA -> XLR cables: https://www.amazon.com/Monoprice-XLR-Male-RCA-Cable/dp/B001VLW398Whelp that looks to be the culprit. It’s definitely a TS plug and not a TRS. Before I order a plug am I better off using an adapter or buy a conversion cable? If a conversion cable should I do rca to xlr? Or does it really not matter?
The instructions on the back clearly state to use CH 1 inputs only for Bridge Mode. Why do you have two inputs?I think you’re mistaken or maybe I am, my understanding is that you have to put the dip switches in parallel mode so that the L and R inputs are combined as a single input. Do you disagree? At any rate, I can give it a shot changing it and report back.
TS is what you want. two metal sections with one black divider. TRS has 3 metal sections with two black dividers.Whelp that looks to be the culprit. It’s definitely a TS plug and not a TRS. Before I order a plug am I better off using an adapter or buy a conversion cable? If a conversion cable should I do rca to xlr? Or does it really not matter?
