  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
sub-amp for aura pro shutting down?
403 Views 1 Reply 2 Participants Last post by  bassbone57
hi..i bought a subwoofer amp from mcm electronics to power my 3 aura pros wired in series..(12ohms). They were the 75w models i believe.
i noticed that on movies that are have continuous bass...it shuts itself off..(polar express, final fantasy 7 - advent children). i touch the heatsinks and its very hot....
im able to bring it back up after a few minutes (off-on) after it has cooled down...
i have it in a small enclosure just big enough for it to fit in...the back of enclosure is a peg-hole board so there is lots of holes. would a small fans cure this? its kind of frustrating during prolonged and heavy bass scenes that it would quit on me..
Status
Not open for further replies.
1 - 2 of 2 Posts
The amp probably needs room to the top and sides to vent properly. You should never put an amp in a place where it can't breath. That's just asking for trouble as heat is the hardest thing on electronics. A fan would only work if it had room around the amp to circulate the air.
-K
1 - 2 of 2 Posts
Status
