Having looked through numerous threads and awesome DIY builds, I'm ready to start my own build. Problem is I don't have the basic skills of trying to design something. Before buying a bunch of wood and wasting it, thought I'd get some help from the experts.
Bottom line is I'm trying to build something closely resembling this: http://www.avsforum.com/forum/155-d...nt-center.html#/forumsite/3207/topics/1685882
I'd also like to get down to the 15-16Hz range to get the full listening experience.
Can someone help me design this so I have some sort of a blueprint to go off of?
Here are a few of my limitations:
Budget: $1000 +/-, but less would be better
Room size: 20' x 20' with 10' ceiling, no side walls (to left of sitting position is sliding glass door to backyard, to the right is open to the front door).
Front wall is 109" across, but I have 2 floorstanding speakers that will eat up 26", so useable sub box space is 83" wide
Sub box depth should be no more than 22-24" give or take so as not to extend too far into the room
Sub box height is not a limiting factor, but I am going to place my center speaker, cable box, DVD player, and receiver on a shelf on top so probably not more than 3' tall, give or take. Plus my TV is will be sitting on top of the cabinet as well.
Some specific questions I have:
1. Should I enclose the sub in the cabinet or do I need it to be exposed on a side somewhere? It would be nice to have it hidden for aesthetics, but what is best for functionality?
2. Should I consider dual opposed subs? I read somewhere that might reduce vibrations since I will have all my equipment sitting on this beast.
3. Should I build sealed or ported? This setup is mostly going to be used for TV/movies, and it would be nice to feel the couch shake a little. I'm afraid if I went ported my limited knowledge of how to get it done properly would result in a bad sounding system.
I have been considering the following equipment:
1. Sub drivers: SI HT18 or Dayton Ultimax 18. I'm leaning toward the SI based on price alone, if the ultimax are that much better than I would spend the extra $100
2. Amp: Inuke1000DSP for 1 sub, or the Inuke3000DSP for duals
3. Sub material: 3/4" MDF with possible veneer or I'll shop around locally to find some quality Baltic Birch 3/4".
Thanks in advance to any and all who have read this far.
